Used Adjust AI, Impression, Texture, finished with Corel Painter 2020
Very cool painting technique …
Raquel, when did Painter 2020 come out? Usually Corel hounds me to death but your post was the first I heard of it. I think I turned off the notices. I have 2018 and I might update this time given the speed increases. Pretty picture.
Fantastic.
absolutely gorgeous
S’nice
print - frame - hang!
Wonderful work, Raquel!
Beautiful painterly look.Well done.
Sweet! Love the color pallet along with the nice light behind the the lighthouse.
Painter 2020 was released about two weeks ago, so you might want to turn on your notices for the special offer to upgrade. You will see a lot of changes, they now are using GPU making Painter so much faster.
I opened Painter 2018 and got the offer on the welcome screen. I just bought and installed it. Installation was a bit strange since I had to reboot and then run a repair to finish the install. It is working ok. Also I just sent a support ticket because the performance test said I don’t have OpenCL in use. I checked using a couple of utilities and they say that Open CL 2 is in use. The Painter score was 1746 and it should be higher.
Just playing with it some now.
One trick, when you first open Painter for the first time, open with a shift start and do a reset to default. If you want to dig deep into the program check out the Digital Art Academy. Skip Allen will be teaching a class for Painter 2020. You can ask questions and he can answer them.
Check out the tutorials in the welcome screen that can help with the Open CL 2. I have a laptop with a score of 199 and my desktop is 5736. Painter still works on my laptop, although I don’t use it much.
Cool image, Very nice technique!
Even though I found some info about GPU settings nothing really helped. Painter still runs well due to using 9 cores of my CPU but it won’t use the GPU without recognizing OpenCL. I put in a tech support ticket. I would think they tested it on AMD video cards.
