[KNOWN ISSUE] Color shift and burn-in artifacts with Aion on macOS (4K+ inputs)
When using the Aion model on macOS, some exports may show color shifting or burn-in–like artifacts in the output.
This has been observed on:
  • macOS systems
  • 4K and higher resolution inputs
Windows systems using the same settings are not affected.
Workaround
At this time, there is no reliable workaround for this issue on macOS with 4K+ inputs.
Status
The team is aware of the issue and is actively investigating. This post will be updated when more information or a fix is available.
