When I use DeNoise AI as either a stand alone or through Lightroom the image looks great until I bring it back to Lightroom then it looks as though nothing was done…I have used duplicate images just to check and there is no differance between them even though when in DeNoise it looks outstanding.
Do you used the File-> Save (Ctrl+S) option to update the images?
Using the Save as button creates a new image.
I have tried that and the save as option …both.
Please go to Help-> Graphics Info, press the Copy button and post the info here please.
Also what processing mode are you using, under preferences, CPU or GPU?
I don’t know what I did differently today or whet happened but it worked perfectly on three images
