Is there any point using topaz for camera footage from the last 14 years?
I’ve used Topaz on footage for VHS tapes, and it’s worked wonders. A VHS tape using the Iris AI model would take about 6 hours and improved the quality greatly.
I have Sony cam footage from a camcorder that’s about 10 years old and has created MTS files. I stitch all those together using Adobe Media Encoder (MP4), and then use Gaia, but the results are negligible. Not only that, a 10-minute clip outputting into an MKV file takes about 2 hours. So 6 hours of footage takes 3 or more days to convert.
Viewing the output it really doesn’t seem to be any better and there doesn’t seem to be an AI model that improves the footage. Is there any point using topaz on footage captured by fairly modern camcorders?
i have a fairly high spec machine running with a Nvidia geoforce rtx 3060ti
Well, there’s still camera shake, motion blur and occaisional autofocus failures. And sometimes you might want to enlarge a portion of a full frame.
I assume your MTS files are already at high quality (1080p), the only reason I would see why Topaz would be used for your footage is mainly if you want to upscale your videos (e.g. to 4K). another option is if you need to clean noise in low light conditions for example or camera shake in case you have it and you want to stabilize your footage or convert to high frame rate and/or do slow motion scenes.
the Tool is not meant to make your current already High quality video look “Wow”, it’s not it’s intent.
it’s not a video editing tool. it’s main mission statement is “upscaling”…
If you need none of the above uses cases I mentioned and what @gene-8240 responded, then this is not the tool for you for the video in question.
My footage is purely family videos. As I mentioned it worked wonders on VHS footage from 30 years ago, so it definitely served a purpose. Later camera footage from this past decade there wasn’t much improvement to be made. Maybe if it was faster I’d let it run through my footage but I guess I was trying to find a reason to justify running it for days on my pc. The things you’ve mentioned Cleaning noise in some sections and converting it to a higher frame rate for me presently doesn’t justify the time. So i guess i’ll just leave it and maybe a couple of years down the line if its faster and improves the quality i’ll look into converting these. Thanks for your response and helping me clarify my position.
Thanks appreciate it. will try and get something sorted out later today.
test footage orginal mp4 (sound removed)
Converted Using Gaia
converted using iris
This is a little over 20 seconds of footage. as you can see from the original there doesn’t seem to be much improvement.
set to 1920 x 1090
orginal pixel type
letterbox pillarbox
25fps ( orginal)
stabilization off
motion debur - on themis
frame interoolation off
video type progressive
ai model - iris face / lq/mq
input conditions is medium quality.
parameters auto
add noise 0
recover detail 0
Any help you could provide would be appreciated.
Thank you.
Wow that a lot sharper thank you. I’ll give those setting a go.
I’m probably going to regret asking this, as I’ve already sharpened all the vhs footage i have, but is there any other settings you’d recommend for vhs?
I got my tapes converted by a guy i met face to face on ebay. he was actually a tv producer and had a lot of video equipment at home and did conversions. so i think i got the best quality that i could from the tapes. I used topaz and its worked wonders, but i also figure if they can be improved then i might as well get it done now.
This is footage from 30 year ago… almost to the day. I am actually happy witht he reult considering its a tape from 30 years ago, but if theres anything you can recommend i’d be more than happy to try it out.
test vhs
iris vhs update
thanks again!
Awesome! Thank You!
Thank you so much for taking the time to do this.! I’ll give this a shot!
