Is there a way to retrieve original preset values through metadata of exported video?
Title speaks for itself.
I just made use of a backdated export without ever saving the project or values I used.
What bugs me is that the app-generated file name only has ‘amq13’ extension attached to the original file name which implies I didn’t actually use AI enhancement - just simply Apollo (?).
What do y’all think. Thanks :blossom:
You used Artemis Medium Quality. That’s amq-13. There should be a tag in the video metadata too that details the settings used.
Hey, thanks! Care to guide me further as MediaInfo seems to not do the job for me since I’m a n00b?
I don’t know if I have MediaInfo… I’m using MKVToolNix and it might be using MediaInfo:
Here it is again in the properties while playing it with MPC-HC:
Right click on the movie and click properties then go to the MediaInfo tab. That one probably is same MediaInfo program you are trying to use.
