I want to use Topaz Video AI to convert 23.976 fps Hollywood films to 48 fps, then play them in 48 fps (probably at 96 hz) on a TV. Is there a way to do this?
Will Custom Resolution Utility work for 48 fps with an EVGA nividia 4070 card, without creating audio sync or screen tearing or any issues like that?
Will either the LG, Sony, or Panasonic OLED TVs accept a 48 fps signal and display it cleanly and evenly at 48 fps without converting it to 50 fps or 60 fps? 48 hz and 96 hz are not official HDMI standards, so chatgpt always told me “no it won’t work. It wont accept the signal or it will convert it to another frame rate” whenever I asked it, every way I could think of, how to make it work. Then one day I specifically mentioned Custom Resolution Utility and then it said yeah if you put the TV in “PC mode” or the equivalent on each TV, usually it will respect whatever frame rate you give it and output it cleanly. Not sure if true or not, dont want to buy three different OLEDS just to get info from trial and error that they should already make publicly available.
As far as VRR, if it’s as steady in its frame timing as non-VRR modes, and keeps 48fps perfectly when you sent it steady 48fps, and if it does not introduce flicker or other artifacts, then it would work, but chatGPT says that typically it does create such issues, so I may need a way to do this just in non-VRR modes.
"As pointed out to FlatpanelsHD by the CTA and Dolby, CTA-861-G was adopted into the HDMI 2.1 specification, meaning that HDMI 2.1 for the first time in a standardized manner made it possible to support 48Hz over HDMI in TVs, media players, game consoles etc.
However, HDMI 2.1 does not mandate 48Hz support, leaving it up to the individual manufacturer to implement it."
which I always have a problem with such discussion, they talking about 48fps from movies and then the 48Hz support for HDMI, but no one differs/exlains hot it handles Frequency and FPS, you can have 48fps from the video and player gives this for example with 60Hz out, what happens here. I don’t know why they never differentiate.
Video AI can export the videos out at 48fps using the frame interpolation models like Chronos, but how those are played back on a TV screen is a different matter. Have not tested pushing a video to an OLED though.
What is FFmpeg? Is it simple to use? I thought Topaz was supposed to be the best FI out there or something like that. You’re saying it’s blurry and not as good as FFmpeg?
50fps would probably be great (as long as it doesn’t create perceivable difference in audio cuts from the frames. 48 would preserve that the best I think) but why isn’t 50fps from Topaz better than FFmpeg?
FFmpeg is a multimedia framework for video processing to do near everything like decode, encode, transcode, mux, demux, stream, filters, crop convert…and play streams. So it’s lib you can download for free use his command line where can do all the stuff with video and audio streams. TVAI uses it like tons of other programs
if you don’t want go into this rabbit hole using the CLI and all the commands, you can use tons of GUI based applications, “Avidemux” is one of them has a builtin filter “Resample" where you can freely change fps, then it does copy or drop frames to reach your desired new fps and the video length does not change.
Normally we don’t want double frames in a video but when it comes to TVs maybe higher fps helps reduce Jitter Effect in motions fast OLED pixels produces. But this has to be tested on TV if you can see optical improvement.
