Is it Possible to Unpixelate an Intentionally Pixelated 4k Video of Someone's Face?
Hello,
I am wondering about the current and future abilities of unpixelisation software.
I’d seen this video which made it look like it’s very easy to unpixelate text when in a video, I believe having multiple frames and movement helps make it easier: https://www.youtube.com/watch?v=acKYYwcxpGk
What I’m wondering is whether this applies to human faces also when in videos? So for example let’s say I intentionally pixelate my face like this and create 4k videos of me talking, moving my head around slightly etc looking similar to this.
r/digitalforensics - Is it Possible to Unpixelate an Intentionally Pixelated 4k Video of Someone's Face?|750xauto
To what extent could the image be unpixelated and the face of the person revealed? I think if there is lots of movement and the image is 4k it will help but how close to the actual person underneath can you get? It seems with text you can get it very exact but with a persons face is this harder? I know you can get AI to have a guess at a pixelated face but it generally will only be that, an estimate based on info. For example I got it to unpixelate the above and the image it came up with was a fair bit away from the original.
Gemini tells me there is software which can depixate videos/images but I tried some of its suggestions and none of them worked very well, possibly as I wasn’t using them correctly.
Let me know what you guys think is possible here? Or if it’s likely we’ll be able to fully depixelate images/videos like the above in the near future with AI advances.
Any help would be much appreciated!
Thanks
Even if you get a face to show up after depixelating with AI, it will be a figment of the training data, nothing more—very much not the original face.
Data is missing, so any reconstruction is only possible based on probabilities—in short, guessing or imagination. But that’s not how faces are created in criminal investigations. There, witnesses describe shapes and colors of skin, hair, eye, and so on, and whatever is unknown is simply left out. This means the result isn’t a complete image, but it can still be enough to identify someone.
That’s not the case here. You might get a vague sense of what it could be, but the distinctive features are missing. And what you’re aiming for is a fully depixelated, detailed image of the real face—that’s not possible because the necessary data simply isn’t there. You can only make guesses and same does an AI, can give you sharp results, but the result then is just fantasy
