Is anyone else having issues with importing photos from Topaz Denoise to Lightroom (LR)?
Is anyone else having issues with using Topaz DeNoise in Lightroom? It was working perfectly, now when I export a photo to Topaz, it processes it, but just hangs when I want to export it back to Lightroom. I use LR not Lightroom Classic. HELP!!!
Hi.
I wasn’t aware that Lightroom is now compatible with plug-in’s sorry, but, I don’t use Lightroom myself because, Classic is the better option for my workflow. Bearing that in mind, here’s a few tips that may help
There are a few possible reasons why Topaz Denoise isn’t exporting back to Lightroom.
  1. If you’re on Windows, try right-clicking on the Topaz Denoise executable file, selecting Properties > Compatibility, and checking Run this program as an administrator
  2. Close Lightroom completely, then reinstall the Topaz Photo AI plugin. After reinstalling, reopen Lightroom and check File > Plug-ins Extras to see if the plugin is properly recognized
  3. Since Denoise is GPU-intensive, outdated graphics drivers can cause issues. Make sure your GPU drivers are up to date by downloading the latest version from NVIDIA, AMD, or Intel
  4. Ensure that Lightroom is updated with the latest version. Having said that, sometimes compatibility issues arise after an update, so checking for patches or fixes from Adobe might help obviously you can’t do this with DeNoise as it is now discontinued
If none of these steps work, you might want to contact Topaz Support or perhaps someone else from the community with a greater knowledge of Lightroom might like to step in and help
Here’s the link to contact Topaz Support directly
Topazlabs Support
support@topazlabs.com
