Anyone could explain what this is and how to use it?
This is just a guess.
When doing a second pass, it will let you pick what resolution the first pass goes to instead of just auto. Of course you can also pick auto.
so what is the Resolution under “Video” controls? the 2nd pass output resolution?
and what is “Auto” (what resolution would it output)?
Yes, that’s the final resolution.
Someone in the main topic said they did some tests on what auto will select here.
Yes, that is essentially correct.
What this feature does is allow users to choose which level of the upscale process is being handled by the models selected.
For example, if you are using Proteus for the first pass and Artemis for the second pass and you know that you only want Artemis to control the upscale, if you have an upscale factor of 2 you would want to set Proteus to 1x (or Auto) and then Artemis to 2x.
