Installation Improvement | Allow Installing Multiple Versions In Parallel
There doesn’t seem to be any options in the installer to choose a custom installation directory.
Has anyone successfully installed and run more than one version of Photo AI on Windows?
Thanks
@david.123 The only way to have two different versions is to have the released version and a beta/alpha version.
Please consider allowing custom installation directories for the installer and allowing multiple parallel installations. I would like to be able to do performance comparisons and quality comparisons between versions and it’s a huge hassle to have to remove one to install another.
Thanks!
Agree! I would also like this!
Portable install please!
I really like the “Low Resolution” Model in 6.0.0
However, I would like to be able to have an up-to-date version as well…
I’m afraid this may not work since programs typically install themselves in many places on your computer, for instance on Windows 10 you’ll have Gigapixel AI sitting in:
C:\Program Files\Topaz Labs LLC\Topaz Gigapixel AI
as well as:
C:\Users\ {User} \AppData\Local\Topaz Labs LLC\Topaz Gigapixel AI
Same goes for Photo AI, I guess. There are also registry records and perhaps other structures I’m not aware of, that refer to the original folder name. Also, even if you change AppData’s subfolder name, Topaz will create a new folder with the original name, the moment you launch the software, and it will interfere will your other installed version, even if you succeed with installation.
I’m going to close this request since the new versions of Photo have enough options for model selection. I would suggest that rather than phase out older models, they be retained with an option to ‘enable legacy models’.
