In-app Low Power mode no longer works on Mac
At some point after TVAI v6.x, and up to and including v1.3.1, the app’s low power mode has stopped working on Mac. I wondered at first if this was due to a recent change in MacOS, but that hypothesis was eliminated by running TVAI v6, where low power mode still works as intended on Tahoe 26.4.1.
Now, the only way to get the equivalent effect i.e. moving the processing to the Neural Engine (ANE) where possible, is the cumbersome process of switching on the MacOS Low Power mode prior to starting the rendering and then to switch it off again after the rendering has started. The processing then remains on the ANE, as expected, after switching to full power mode.
When checking the log file, I see that the Low Power mode switch “instances=0” is being passed to FFmpeg in v1.3.1. Running from the CLI also exhibits the same issue. This implies the bug is in the Topaz FFmpeg. Or perhaps that change was intentional and the UI hasn’t been updated? Either way, there’s a bug.
In exactly which version this started, I don’t know.
Andy
Weird to hear that is not holding for you Andy. Can you send me those logs to put in front of the devs for review? Going to also see if I can get this replicated on some of the Mac systems in the office, as I dont think any of them have been updated to 26.4.1 at this time.
help@topazlabs.com
Thanks.
Hi Kyle, I’m afraid I won’t be providing any logs.
However, to further assist you and the dev team, I have done some basic testing here. I can confirm this issue occurs on MacOS Sequoia 15.7.5 as well as Tahoe 26.4.1.
Also, to help narrow down where the relevant change occurred, Low Power mode works as expected in TVAI 7.1.5 but NOT in the 7.2.0.3 Beta or TV v1.x.
In all cases of my testing, I have been using SD sources with Artemis, Proteus and Iris. The same issue occurs on my M2 Air and M3 Ultra Studio.
So I don’t see you having any problem reproducing the issue. Apart from logs, I’m happy to provide more info if needed.
Regards
Andy
