Importing Prores with Alpha and retaining alpha channel on exporting
I’m pretty sure this has been discussed plenty of times but I wanna know if video ai can retain alpha channel of imported PRORES or even EXR sequence in the newer version. this feature would be very convenient. Thanks
Yes the alpha channel can be retained and exported back out as long as a compatible codec and format is selected for export.
Video - Quicktime Animation
Image - PNF, TIFF
The alpha can not currently be retained if applying Frame Interpolation, Stabilization or Motion Deblur on the clip.
Is there any update on alpha channel retention with frame interpolation? (25>59.94 Prores 4444 w alpha)
The team is still working on this at this time.
