Hyperion 2.5 & ACES
Hi Team,
First time posting. Trying to use Topaz Hyperion 2.5 with 16 bit half float output in a professional project.
I am then doing some colour retouches in Fusion.
The documentation says that 16-bit half-float EXR uses ACES2065-1. However when i inspect the meta-data of any individual EXR after downloading it says Linear Rec.2020
Using OCIO Color Space Node in Fusion If i set source to ACES2065-1 and output space to SRGB it looks quite red. When i choose Linear Rec.2020 it looks more accurate to the original.
However, regardless of which one i choose the lighting still very blown out and crunchy i have to adjust this by using a colorcorrector node and reducing the gain substantially.
Note that I have also used output space as ACEScg and just done the SRGB display transfrom in the view settings as well with similar results.
So my questions are these:
  1. What is happening to the ACES2065-1 color space to make it change to linear Rec.2020? Am i downloading incorrectly from the website? Is a colour transform being applied twice in the back end by mistake?
  2. If it isnt a problem with the outputs and instead a problem with my setup id love to know what my issue is because I have worked with this workflow in our team for years now doing CGI.
Thanks in advance for your help.
Cheers,
Keith
Can you give a link to the documentation you read?
Its my understanding that currently the cloud rendering for Hyperion 2.5 only outputs BT.2020 Linear for 16-bit EXRs. The ACES2065-1 EXR output is limited to local rendering for pro licences, as stated in the beta patch notes:
https://community.topazlabs.com/t/topaz-video-1-7-1-1-beta/104591/1
Unless the web apps are getting more output options than the desktop apps?
Documentation I’m referring to is in this link here:
Documentation is here
https://developer.topazlabs.com/video-models/video-utilities/hyperion-2.5-sdr-to-hdr-new
