How to fix VCOMP140.DLL missing?
I’ve been using Topaz Video Enhance 2.6.4 for a few years, and want to upgrade to the most current version 5.2.3.
I copied my TopazVideoEnhanceAI-2.6.4-windows-x64-Full-Installer.exe from my old PC to my new upgraded(more RAM, better CPU and GPU) to make sure it would run before I upgrade my license to 5.2.3
The install seemed to go fine, asking for my signon and password. On the last page of the install I checked the ‘run now’ box, and nothing happened. When I double-clicked on the desktop icon, it displayed a ‘VCOMP140.DLL not found’
I looked for it on my old PC and didn’t find it. I re-installed 2.6.4.—same issue, I re-booted…same issue.
Any ideas on how to fix this?
Thanks!
I would recommend doing a full uninstall and cleaning of the registry files on the system.
Then go to the Video AI releases - community page and download a clean installer and try the install again. If that doesn’t fix it, email the support team directly at help@topazlabs.com so that we can investigate further.
You need to download https://www.microsoft.com/en-ca/download/details.aspx?id=48145
This is the Visual C++ Redistributable for Visual Studio 2015.
Install both versions.
Thanks for the responses, will try the Visual C++ now.
Yep, that did it. Thanks!
