I’m not so sure if this is related to my hardware, but I do not see anything in the scroll options for Target Bitrate. It would be nice if I was able to change this to a higher value.
I agree with this idea, I would prefer bitrate to go up to 250-300, 180 is ok for 4K but need higher for 8K.
I work with 8K as well, so I need it to encode bitrate far higher, especially when I am encoding at 120fps.
Wouldn’t you just use FFV1 at that point? It’s a lossless compression, so it still tries to save space, but pixel perfect.
TVAI options for FFV1 8K are now wreck, unless getting true example of working settings
ATM ProRes422HQ best working solution for 8K very high quality
Get ready to output 2.5 TB files for 2hours of video (5 if you choose pause/resume option)
If expecting downscaling after to 4K, Lanczos3 DO add aliasing and TVAI Theai is SO slow to expect anything from it, so it is necessary to change ffmpeg settings from lanczos to blackman/mitchell
