Hi,
Small introduction how to get proper GPU monitoring so you can see if the GPU is doing anything.
After i started up the MSI After Burner i change the UI for a better view in the Settings.
Then in Monitoring i set the polling rate to 100ms.
Often the GPU reacts so fast that you don’t see anything in the monitor because it wasn’t read at that moment.
This also happens in the task manager of Windows (actually all the time).
I also throw out things, like fan speedometers, that I don’t want to see.
And then you can make good use of it.
