I have Impression II and Topaz Studio. I can only find Impression II under Plug-in. I’ve understand that one can update Studio to included Impressions in Studio. Is the same plug-in or is it a different? How can I update to Impression in Studio?
If you don’t see Impression listed under Adjustments, you could try selecting “Check for Adjustment Updates” in the Help menu in Studio. That’s supposed to sync Pro Adjustments. Note in Studio, the Impression adjustment is the latest version, i.e. Impression II, even though they just call it Impression.
Best regards
Thanks Scott. I appreciate the help!
