Hi all, I have problem with rendering on my PC with GTX 680 4GB VARM it works only to resolution SD 768x576, problems start with 720p or bigger resolution. How its possible I don’t have any problems on my laptop with MX150 2GB VRAM even with 2160p resolution.
I konw that it is old GPU, but it has OpenGL 4.6 (minimum required is 3.x).
I believe you need the GTX 740 or higher. Check the system requirements on the main website.
