GPU selection not honored for SLP2.5. Output filename not honored
logsForSupport.zip (1.3 MB)
SLP2.5 always uses the first listed GPU (4080 Super) regardless of what is selected (4080Super or 4080).
Secondly, custom filename is not honored. If exporting SLP @2x then at 3x, the 2x file will be overwritten. The filename is a default one: <original_filename>_slp even if I have modified it (i.e. adding “-2x” and “-3x” at the end)
Specs:
Topaz Video 1.6.1
  • Ryzen 5950x, 64GB DDR4 ECC RAM
  • RTX 4080 Super (main slot), RTX 4080 (2nd PCIe x16 slot)
Can provide more info if needed.
At this time, Neuroserver uses the first GPU card, it does not hold the selection to another card from the Preferences Panel. That is being looked at by the devs at this time.
The file name when exporting from the Export As option should retain the chosen name, however, the log entries you shared the outputs are all being shown as the same file name without any change.
Thank you for looking into GPU selection.
Regarding output filenames, it worked for me before. This time around, I saved two presets: SLP2.5 2x, SLP2.5 3x. When toggling between them and then exporting, the custom filename is ignored. Afterwards, the problem appears to stick around. I can try more after my current export completes.
