[Gigaprint] Canvas and Export Options
Also can not export image or save image once the auto correct features are done only send to Gigaprint…? having the option to save and or export the image after auto correction would be a heck of a selling point to other artists…
@foleypro
That’s a great point - so to clarify, after the Print Assistant does the Auto correction - you want the ability to just save the image as well as going to Gigaprint?
yup that would be awesome…as it is right now once you do the print assistant you can not save the image or export it out…just to gigaprint…then after you go to gigaprint and back into the program still no option to export or save it is greyed out in the menu and the export button is still says send to giga-print and not export…?
