Hi folks. I installed Gigapixel on my C drive but installed the data on a different drive to save space. However I’m still finding disk space being used on my C drive when using Gigapixel. So is there a working directory where I can delete temporary files from? It would be good if you could add the path for temp sile to the program preferences.
Although your program files are on the other drive, some files will still need to be written to your C drive. I’ll be sure to raise this to our developers to see if a fix or workaround is possible.
