Because the same application is used for standalone and plugin therefore the architecture is designed that way. You can try raising a support request at the main website asking for this to be changed to suit your workflow.
What type of image are you trying to send to GigaPixel? For example i would like to know the type of image ⊠Jpeg, png etc and the bit depth and ICC profile, should be sRGB, AdobeRGB etc.
standard .jpg, rgb see attachment.
As the color profile is untagged and âUntagged RGBâ isnât just another color space but the lack of one please allocate a RGB profile and try again, I believe it is a issue because there is no profile with the image.
You will need to view the profile you are going to assign, you cannot convert, through Edit-> Assign Profile but there is really only a choice of the RGB profiles, just choose the one that looks best. Probably sRGB.
Don,
Thank you for the help. That did the trick!
Glad thereâs a workaround! Iâll definitely make sure to fix this in an upcoming release, to be more explicit that thatâs the step that needs to be taken at the least.
Taylor please fix this awful red stripes for 4x, 6x, custom upscaling on some jpg and gpu acceleration. Only 2x works correct.
Please post the before and after pictures here.
Iâll need your graphics info as well, which you can get from Help â Graphics Info â Copy, then paste that here. Iâll also need the processing parameters youâre using (GPU vs CPU, OpenVINO on / off, Graphics Memory Consumption, and whether youâre using the maximum quality AI models or not).
I upload example wallpaper to this link:
https://www.dropbox.com/request/n6Dpn4JzhpK6S77JU2Sd
A lot people has this bug when GPU is enabled, but in my config 2x has works correct, only 4x, 6x and custom has red stripes bug. I tested stable and beta driver and this bug is sitll existe.
PC:
Application & Version: Topaz Gigapixel AI Version 5.1.6
Graphics Hardware: GeForce RTX 2080 Ti/PCIe/SSE2
OpenGL Driver: 3.3.0 NVIDIA 460.20
CPU RAM: 16320 MB
Video RAM: 11264 MB
Preview Limit: 8000 Pixels
i7 9700KF + 16GB DDR4 3733CL14 + Windows 10 on NVME SSD.
GPU on: red stripes bug.
GPU off: works correct.
OpenVINO on: works correct.
CPU on: works correct.
Maximum AI on: works correct.
Maximum AI off: works correct.
Memory GPU High, Medium, Low: It doesnât change anything.
Your dropbox doesnât show any file.
Itâs not his Dropbox, itâs one of the Topaz devâs, I believe. You have to upload examples of certain GAI issues there. There seem to be three:
- for overall GAI bugs: https://www.dropbox.com/request/n6Dpn4JzhpK6S77JU2Sd
- for destroyed by multiple JPEG recompressions or sharpening algorithms images to train GAI handle them better: https://www.dropbox.com/request/DTu64l9QnNPnQj5rEsfz
- for GAI grid artifacting issues in GPU mode: https://www.dropbox.com/request/TJE1HGToPJVYblasfCkg
Because this link Dropbox is only to upload âphoto bugsâ and access to file has only N. Bishop.
Strange, all red stripes bug in GPU mode they are with hair in the photo.
PS: Sorry but english is not my native language
Hi. I also uploaded you an example. But basically: if it has hair - it probably has red lines (besides 2x)
Thanks all - this is a nasty bug so will take some time to fix, but Iâve got this on the roadmap for right after our next major update (mid October).
Is Gigapixel AI supports RTX 30series GPU now?
I believe it always has.
I agree, the lack of colour space info on images makes app crash. Once i switch color space and try again it works as it should. Thanks for your help Nick
Glad to have been of help. Iâve found it useful to allow Photoshop to prompt for a colour space each time an image without a defined colour space is opened. This option can be found in Color Settings under the Edit menu in Photoshop for Windows.
perfect, thank you Nick
