Gigapixel v5.1.0
I reproduced the red artifacts on the gorilla face in all three modes (GPU,OV,CPU). These also happen in v.4.2.2, though.
I think he is using a standart user and not an admin account.
An the software did itself install on the admin account because he runned it as a admin via password.
He has to change his account to admin install it and change back to standart.
Then drag and drop will work.
… run from the last dialog on the install.
Eh, are you talking about running the program before the install is finished? :confused:
Didn’t even know that was possible and that is certainly not the case here.
And a reboot, registry cleaning and a fresh install was tried before I posted here with the same result.
No she didn’t.
She didn’t run the install as a admin via password (what that even means). She installed it the same way as all the earlier versions and every other program that’s on the computer, from the one single existing account.
She can’t change the account to something that it already are.
Don’t really know why you talk about me instead of with me… :face_with_raised_eyebrow:
No, on the last dialog before you exit there is a checkbox ticked asking you if you want to run the application.
Please raise a support request at the main website.
