Hi Topaz team,
I’m hitting a consistent, reproducible crash in Gigapixel 1.3.0 on a dual-GPU workstation. Posting full details so you can fix it.
System
- OS: Windows 11
- CPU: Intel Core i9-13900K
- RAM: 128 GB
- GPU 0 (per Gigapixel): NVIDIA RTX PRO 6000 Blackwell Workstation Edition (94 GB VRAM)
- GPU 1 (per Gigapixel): NVIDIA GeForce RTX 5090 (31 GB VRAM)
- App: Topaz Gigapixel 1.3.0
- AI Engine: 2.9.23
What happens
Any enhancement that triggers Face Recovery V3 (Standard V2, High Fidelity V3, etc. with face recovery enabled) fails with:
AI Engine Runtime Exception: Could not run model
The neuroserver subprocess logs:
FileNotFoundError: Input image not found: C:/Users/<user>/AppData/Local/Temp/neuroserver_input.png
ERROR:local_model_service:Error running video restoration: Input image not found...
Root cause (from the log)
The neuroserver enumerates GPUs in a different order than the host app:
- Host Gigapixel order: [0] RTX PRO 6000, [1] RTX 5090
- Neuroserver order: [0] RTX PRO 6000, [1] RTX 5090 — but
translateDeviceIdkeeps remapping 0 → 1 and 1 → 0 and restarting the runner each time.
For every face recovery call I see this sequence repeated:
NeuroserverProcessor::setupAndLoad model=FaceRecoveryV3 device=0- Runner starts, lists GPUs
translateDeviceId: translated deviceId 0 -> 1, restarting runner- Runner is killed and a new one started on the “correct” GPU
- Gigapixel writes the input PNG to
%TEMP%\neuroserver_input.pngfor the first runner - The new runner starts, but by the time it tries to read the input file, it’s gone →
FileNotFoundError - Task fails with
MODEL_INFERENCE_ERROR
Classic race condition between the input-file write and the runner restart triggered by GPU-index translation.
Secondary issue (same log)
Throughout the run there are dozens of:
Error | Attempting to set stage that does not exist in stage weights map: "FaceRecoveryV3"
Warn | Progress stage missing, attempting to auto-fix (imageai bug?)
So the progress/stage tracker doesn’t know about FaceRecoveryV3 either — likely related, and at minimum makes the progress bar useless during face recovery.
Reproducibility
100% on my machine. Any image that triggers face recovery fails on the first attempt. Occasionally a retry succeeds when the runner happens to land on the right GPU before the temp file is wiped, but most of the time it loops and fails.
Workaround
Forcing a single GPU in Preferences avoids the translateDeviceId restart and the crash goes away — but obviously that defeats the point of having two GPUs.
What I’d ask you to fix
- Make GPU enumeration consistent between the host app and the neuroserver, so
translateDeviceIdnever has to remap and restart the runner. - If a runner restart is needed, write the input file after the final runner is up — not before.
- Register
FaceRecoveryV3in the stage weights map so the progress tracker stops spamming errors.
Thanks!
