Is there a way to do frame interpolation with custom value?
With Video Enhance AI v2.6.3 I could select 150% or could enter 125%.
When entering 1.5 in Video AI 3.3.x, I got no slow down (1:1 or 1x).
I often need 150% or 1.5x slow down. For now I use Video Enhance AI v2.6.3 for this task. But this version has some bugs (missing first frame, duplacate frames at the end of file).
How can I archive custom slow motion speed with Video AI 3.3.x ?
Hi, yes, you can use the custom input the same way in v3.3.10 or any of the v3.x builds.
For example, if you want 64% of the original speed, the slow-mo factor would be 1/0.64 = 1.5625.
It doesn’t work for me.
I can enter 0.5 or 1.5 or 5, I always get 1x speed - no slow motion.
I’m using a german version of Windows 10. I had to change the localization to English (USA), otherwise only the german notation of 0,5 or 1,5 (in Germany decimals are separated by a comma instead of a dot) will be accepted. But this also lead to 1x speed.
We’re currently working on a fix for custom frame interpolation factors and we hope to have it out as soon as possible!
