Hello,
i had a quick chat with amazing Emily on deinterlacing issue and it was suggested I raise the topic here (apologies for the late reply, Emily, i was on medical leave over the weekend).
when i use Dione Dv/Tv v1/v2 to deinterlace videos and double FPS, it sometimes does wonderful job. but i came across couple recent videos where is is doubling the last frame in FPS. I suspect that the issue is that it incorrectly establishes the FPS in original video (for instance 25 when it is 23.9 and thus converts video to 50 FPS, instead of 48). It then
Case example: if my FPS is 10, then Topaz Enhance will convert it like this 1A 1B 2A 2B 3A 3B 4A 4B 5A 5B 6A 6B 7A 7B 8A 8B 9A 9B 10A 10B 10A 10B and then continues 11A 11B etc…
it is especially disruptive when there is dynamic camera and it “plucks” the video movement. I can override this issue if i deinterlace video in Avidemux using Yadif method doubling the FPS. then i can upscale video in Topaz but:
- quality seems to be worse/sketchier
- Topaz now has double the frames to process to it doubles the processing time as well. (instead of processing 20k frames via Dione Tv, it now has to process 40k frames via Artemis)
Is there a way to fix this please?
I have uploaded the files here
https://easyupload.io/m/mxffqn
Thank you very much for any help.
best regards
Thomas
