As per the subject, please add this option to convert the fps of 23.976 source files to 59.94.
Thanks!
Thanks!
You can just enter the desired FPS in the drop-down entry.
I suppose it could still be nice for them to add it as one of the default options.
Thanks for pointing out the free-form solution. Would still like the preset though!
It’s not a standard frame rate by any account, so that dips into what other non-standard rates should they include and why.
That’s why I’ve been running the interpolation models at 2.5x because 59.94 fps is standard. (Though, I understand 2x should be cleaner with less potential for sounds becoming out of sync.)
I already asked them for set multipliers actually, 2x 4x etc. that would be good to have too
I set mine at 59.94 too, but there’s a lot to be said for 2x; if for nothing else, bitrate, which can get pretty high at 4K, at near 60 fps. Not every device can really do too high bitrates.
Doh! I didn’t even think of this. Have you seen any issues with audio / sync when using 2.5x?
I go back and forth on if there’s sync issues with it or not. The latest show I did with it, I think it was totally synchronized. I just went back to it and did some spot-checking, and I still think it’s in sync.
I used to notice that it would cycle in and out of synchronization, but I had also been doing some abnormal things with movies before TVAI, that probably messed with it.
Changed the title/request details!
