Hello.
Do Topaz products use floating-point or integer operations when run on the CPU? I ask, because Intel’s E cores are efficient for integer, but weak for floating-point.
Hello.
Windows pushes GPAI to E cores when it is run in the background. This seems to suggest Integer load?!
