When using DeNoise Raw my images come out looking flat and dingy. I am using the application as a stand-alone and saving my images as DNGs. I can pull them into LRC but even with that the colors feel a bit off? Could I be doing something incorrectly to cause this?
I moved this as you said you are using DeNoise, is that so or are you using Photo AI?
Using DeNoise
Ok you will need to raise a support request at the main website. Other users may pick it up though.
You may also want to check your GPU drivers are up to date from the manufacturers website.
Go to Help → Graphics info, press copy and paste the info here.
Application & Version: Topaz DeNoise AI Version 3.7.2
Operating System: Windows 11 Version 2009
Graphics Hardware: NVIDIA GeForce RTX 3060/PCIe/SSE2
OpenGL Driver: 3.3.0 NVIDIA 531.30
CPU RAM: 16071 MB
Video RAM: 12288 MB
Preview Limit: 8000 Pixels
The latest drivers are 536.67 and they can be downloaded from the NVIDIA website. That may help.
