Feature Improvement | Remove "Sample Images" In Right Panel Window
I just upgraded to Photo AI 3…
How do I remove “sample images” in the Sidebar Navigation window?
Mac OS
Was there a fix for removing the sample images? Still trying to find this. My current solution, which is annoying, is to select all images and close all images. But I have to do this every time I open the application.
Unfortunately, no. I just sent another “get help” message to Topaz.
You are not talking about the sample images in the right panel, what you experience is havin g the sample images on the film strip when you open the app. This can be turned off in the preferences
Hello Alexandre… actually it is the sample images in the right panel I would like to remove when opening Photo AI. It appeared in 3.0 and there is no preference to remove them… fortunately, I don’t need them as a tutorial.
My reply was for Lauren, as it was mentionned that their soulution was to select all the files and close them. This is referring to the sample images in the filmstrip, not on the right panel.
For the right panel, there is still no way to remove them. However, as soon as you import a file, these will go away. They are only present when the app is in idle mode. In other words, they won’t prevent you from using the app normally.
