Feature improvement | Ctrl+W needs to be done twice to close images
Well, I am using Gigapixel 1.0.7 on Windows 10. I noticed if I use the keyboard combination “Ctrl+W” it doesn’t immediately close the current image. I have to do it twice. It works the second time. The same issue exists with “Ctrl+Shift+W”.
I am checking with the development team to see if this is a bug or the expected behavior. Thank you for flagging
