Face Recovery in Topaz Image Web
Where is this Feature in Image Web?
I can’t find it
Hi Christian.
Face Recovery v3 Alpha is in Topaz Image Web, located under the Restore - Faces model category.
​To locate and use it in Topaz Image Web:
  1. ​Open your workspace and select or upload your image.
  2. ​Look at the right-hand Enhancements / Models sidebar.
  3. ​Scroll down to the Restore group and expand Restore - Faces.
  4. ​Select Face Recovery v3 Alpha from the dropdown list.
​Using the Reference Image requirement:
Because this alpha model requires a reference image to guide feature reconstruction, selecting it opens an Upload Reference Image prompt. Drop in a clear shot of the target face, and the dual sliders for Enhancement Strength and Recovery Strength will activate.
Here’s a bit of info about this model and a link for more information about Topaz Image Web
Next-Generation Face Recovery
An advanced face recovery model offering separate controls for enhancement strength and recovery strength. Requires a reference image. Currently in alpha — results may vary depending on source quality.
Hope this helps
