The attached photo is with an old point and shoot camera from 2011 and Topaz has done a good job restoring the image with face recovery. It is let down though when you zoom in. The hairstyle at the top shows an obvious demarcation, which is annoying and could easily be improved by your AI tool to treat the hair as one object. There is too much of a discernible difference. I have noticed a number of photos that it does this to which if it wasn’t for that factor would be fine from the low resolution image to begin with. Can you please fix this shortcoming?
Regards
Anthony Car
Thanks for sharing this example, I will be sure to share this with the team working on Face Recovery.
