I’ve used topaz for years, and it is a great tool. However, it is not quite still there yet for a CGI pipeline.
For example, I render from Cinema4D with redshift into a 32bit EXR linear with 16bit half floats and DWAB compression.
Topaz can read this and work with it great.
However, I want to do something simple, 4k uprez, then export a like-for-like sequence. I can’t.
Please add compression options to EXR export along with half float, and also the alpha option too.
