Export Queue management
It would be so helpful to have the ability to manage the export queue. It would enable the user to do the following:
  • Change the order of items in the queue
    • Preferably by dragging up and down
    • But at a mininum, to move any item to the top of the queue
  • Sort the queue by various criteria
  • Quickly filter the queue by tying in a few characters (e.g. file name) so users can find a particular video in the queue (to confirm that it’s there, for example)
  • When adding a new item to the queue, offer the user the option to “put it at the top and start now” and then automatically temporarily pause the item currently being rendered, and then automatically resume that item once the top item is done.
I would second this.
To me more importantly I would preferf the return of the olb behaviour of hbeing able to setup multiple projects then start them all and have them process one at a time rather than trying to do them all at once.
Also with scene detention enabled it seems to spend half its time “Estinamting”, knowing how long a mini-operation takes dose not good and should be removed to speed up the process.
