[Please describe your idea and how it would be useful to you in your workflow.]
The main difference being that that i3 has two cores and the i7 has four.
Both of those are less than ideal for TVAI. TVAI makes heavy use of at least 8 cores.
Although the main work is for the GPU Load, most people dont know that there is also a powerfull CPU needed to have a fast workflow… I work with a 12/24 core and run on 35-40% on my tests, but i see i need a faster GPU for now
