Hi
I’m trying to sharpen an out of focus piece of video footage and I’m trying everything i can but everything I do it fails.
Here is the error message:
- Error message from AI engine: download failed. - Error message from AI engine: model failed.
Hi
That is pointing to a connection and download issue. Can you pull the logs from the app and send to the support team at help@topazlabs.com for review?
If you are running a VPN or strict anti-virus or firewall settings, try disabling those and running the process again to see if that clears the issue.
