Error using Starlight Precise 2.6 on Mac
Mac Studio 26.5.2 Topaz Video 1.7.0
Was almost at the end of a 2 day render when the render failed with an error message “Please contact support …”
logsForSupport.zip (42.7 KB)
The log shared is from Topaz Video 1.0.0 and only shows a Proteus process running.
Do you have an updated log to share for review?
Attached the latest logs. Should be running the latest version but “about” isn’t responding as am in the middle of a multi-day render. Haven’t run a Proteus process for some time, just Starlight Precise.
Looked at the …Main log and it just seems to be showing 2025, not the render that failed. The log file was just created from the app.
The 2nd 2 day render also errored out telling me to contact support. Failure again seems to have happened at the very end of the render.
Topaz Video 1.7.0.
Something very odd is going on here, as the log is showing that 2025 date, but it was written on August 18th, 2026. Its also being shown as Topaz Video 1.0.0.
I would recommend doing a full uninstall and reinstall of the app and clear the Plist files using the steps below:
  1. Uninstall Topaz Video AI by dragging and dropping the app into the trash bin
  2. Delete the plist files & empty the trash bin
    How To Delete Your Plist Files
  3. Reboot your Mac
  4. Reinstall - Topaz Video | 1.7.0 | Mac
After the reinstall and reboot the problem is worse. A new Starlight 2.6 render has been stuck for ~4 hours at 15% “downloading model”.
logsForSupport.zip (91.9 KB)
Very odd all the way around.
Let’s have you roll back to version 1.6.1 and install that as the 1.7.0 has a few bugs that are being investigated right now that could be contributing here.
Topaz Video |1.6.1 | - Mac
1.6.1 worked without errors.
When should I try 1.7.0 again?
Dave
The team is working on a beta version right now for 1.7.1.1 that looks promising, if that all goes well, that will be pushed in the near future.
Thanks for your great support.
You are more than welcome, we do what we can.
If you want to try the beta out you can do so by joining the group via the link below.
Video Beta Tester
