My Question: If I upscale to say 9000 ppi then increase an upscale on top of that number, or even 3 times, do I lose quality when I re-upscale to get increased pixels?
Hi David.
Firstly, please remove your email address
Image quality will depend on the original source material
Here’s the information you need from Topaz
Upscale
Use Upscale to increase the number of pixels in your image.
There are two methods to resize your image:
SCALE FACTOR will upscale your image by a multiplier of up to 6x
DIMENSIONS will upscale your image by using a custom width or height
32,000px on the longest side is the maximum dimension for upscaling, with the largest image possible being 32,000×32,000 (~1 GigaPixel).
If you need a different ratio than the original, apply a Crop to the image first
Custom
Click “Custom” as the multiplier
In the “Scale factor” field, type in your multiplier
Press Enter
The dimensions of your image automatically adjust after you set the scale. Custom scales can be specified by up to 2 decimal points.
The default Pixel density is 300. This can be set in your preferences.
Use the 1x scale to enhance your image without upscaling.
Custom scale factors below 1x (0.9-0.2x) can be used to downscale images to prepare for web or to help eliminate false resolution.
Set Output Size
From the menus go to your preferences and select “Upscale and resize” under Preferences > Settings.
In Resize type, change the drop down boxes to Set output type.
Select your type (Scale, Width, Height, Longest), then choose a value.
You also have the option to define a default pixel density.
Longest Side
Image batches can be scaled by the longest side.
To enable longest side, select which images you want to upscale by clicking the check boxes in the file list.
When multiple images are selected, the Dimensions show mixed indicating that there are multiple values across all images.
Under Longest edge, type in the value you want to apply.
The longest side option does not appear when only one image is selected.
Hope this helps
