Education | Sharpen AI | "Error: Could Not Save Application Data"
I have downloaded and deleted and downloaded again Sharpen AI 4.1.0 and keep getting this message: “Could Not Save Application Data”. “A necessary file for the application to function could not be saved to your application directory. Please ensure the application directory has the correct permissions. Try re-installing the application and contacting support if the issue persists.”
I have downloaded and installed DeNoise AI, Gigapixel AI and JPEG to RAW AI without an issue.
Please reach out to us at the following link:
Topaz Labs | Support Page
Or you can send us an email at help@topazlabs.com
I have the same problem, with Mac OS Sequoia. Also, when I activate it, the next time I try to use it I’m logged out…
I have the same issue
I have the same issue, does anyone know how to fix this?
This is a known conflict for Sharpen AI. Please follow the steps below to resolve this:
  1. Close Sharpen AI if it’s open.
  2. Open Finder and go to Go > Go to Folder…
  3. Type in “~/Library/Application Support/Topaz Labs LLC/” or you can copy and paste it.
  4. Check for a Topaz Sharpen AI folder here. If there isn’t one, create one and name it Topaz Sharpen AI.
  5. After doing this, please close Finder, open Sharpen AI again, and download the models. The application will automatically download the models due to the alteration of the file destination.
Thanks!! Problem solved doing that in a MacBook Pro M3 PRO.
This helped me, thank you! MacOS 14.7x on M3 MBP
this didn’t help me followed the steps copied and paste in to finder Go-go to folder search bar and all I get is a bleep and no folders
MacOS 15.4.1 on M4 Macbook Air,This didn’t help me,how to fix this?
Unfortunately this didn’t work, and the folder was already there. I do have all my user directories on an external SSD, is this the problem?
Hi.
Yes, No and it Depends.
YES:
Although, it’s possible to have the Files on a Separate Drive
NO:
It isn’t Recommended by Topaz
Depends:
Some users have reported that Topaz Sharpen AI isn’t Compatible with the Apple Operating System however, if you are using a Windows Machine then, try Reinstalling the Application and System Files back onto your main Drive.
Hope this helps
Thanks worked great for Tahoe 26.3
