Education | How To Use Denoise
Hello, when i choose Denoise all it’s not really working the same everywhere on the picture
There is some space with and some without
And i can’t fix it
I’m really not satisfied about Topaz photo
Am i alone ?
Here and exemple , look at the jacket, the arm of the girl the back of the girl .. I don’t know how to do
This can be caused by one or a combination of these reasons:
1 > Insufficiant Grpahic memory, test going to Edit > Preferences > General > AI Processor > CPU. Click Save and reimport the file.
2> Using Denoise on a RAW file. If you shoot RAW, to make sure to import the RAW file in Photo AI and RAW Denoise will kick in and remove the RAW noise completely. I suspect this is a RAW file since there is overall noise here. Or it is a very compressed non-RAW file and you can see step 3 if that is the case.
3> If you shoot JPEG, then yes you can use Denoise here, but make sure to put the Original Slider strength way up.
Hi.
Following on from Ange’s expert information.
Here’s a couple of links from Topaz about both Photo AI’s RAW Denoise & Non RAW Denoise
Also, a youtube video from Topaz about using Photo AI Denoise
Hope this helps
