Education | How To Find Sliding Horizontal Bar For Split View
--------Working with Toapz V 3.6.0, though i saw this with earlier versions- split screen doesn’t seem to work. I can get the double image to show up, but when I select split view, only the original appears. working with windows 11.
IF YOU HAVE AN ISSUE:
TO CREATE A FORUM TOPIC
  • Give as many details as you can on the issue you are experimenting.
  • Workflow steps you do, if using the standalone or plugin. File Type used is RAW or JPEG?*
Hi.
Can you confirm you’re asking about Split View and not Side By Side View if, you’re asking about Split View then, please follow the guidelines below
Don’t panic the good news is Split View is working
This is happening because, Photo AI remembers the last place you left the split line before you closed the application so, the next time you open Photo AI and click on Split View the split line will be where you left it and the reason you’re not seeing it is because you left it all the to the right or left of the image
For instance, you may have placed the line to the far right to view the image without any enhancements applied or you could have placed it to the far left to see the whole image with the enhancements applied.
Then you shutdown Photo AI and when you next open Photo AI and select Split View the line has mysteriously disappeared
Basically, the split line is on the right or left of the image
Hope this helps
The “Don’t panic the good news is Split View is working” is gold ahah
@john.philbrick - make sure to see Andy’s message and post if any issues remain after testing this! If you go to dark view in Edit > Preferences > General > Color Scheme to Dark the bar is more noticeable
Got it! Thank you. It was actually off to the side of the original, so didn’t get picked up as i swept across the photo.
