I just downloaded Ai4. In super focus I notice there is “none” , “minor” and “major” options. Does “none” mean there is no alteration to focus in picture? Or do the terms none, minor, major really mean: minimal focus improvement, moderate focus improvement and extreme focus improvement?
Also I notice that when I use super focus it affects the whole picture and not just the subject–can only the subject be selected for superfoucs leaving the background alone?
These are for Focus Boost options. Pick one depending on your blur level. Extreme blur should use Major focus boost. There is a little “i” icon in-app that explains further, the focus boost will downscale the image first and could give better results depending on your image type!
Note that it will not appear on small images as downscaling a small image is not possible.
