Hi guys,
I’ve been having really weird color shift issues with Topaz lately, to a point I can hardly use it with my regular workflow.
I’m using Lightroom classic V14.0.1 and Topaz Photo AI 3.3.1 (recently updated, the bug was there before though). OS is Windows 10.
On the left you can see the RAW before using Topaz. On the right I’ve used Topaz (RAW Denoise and Sharpen).
All settings are just the same, also the picture looks fine in the preview in Topaz. It just comes out like this after exporting back to LR.
I tried to look for a solution myself and found a thread where somebody recommended to not go via “File - Plugin - Process with Topaz” but “Photo - Edit in Topaz”. This way, the picture comes out fine:
but since it works with TIFF format, I can’t use RAW denoise and the normal denoise doesn’t give a comparable result. Also, I can’t edit several photos at once. So this definitely isn’t a permanent solution.
If I don’t use Lightroom but load the photos directly into Topaz, the issue is the same - so it doesn’t seem to be a LR issue, but Topaz related:
(left RAW, right imported into LR after editing directly into Topaz)
I’ve tried uninstalling and reinstalling Topaz, LR and even the Creative Cloud, which didn’t have any effect at all.
I’ve found that several other people had the same issue, especially with the Alpha 7R V, which I also use. The only other solution I found was in this thread where the camera profile was “Camera ST” after the reimport into LR - but in my case, it’s the same (Adobe Color) as in the original photo.
So far, nothing helps and I can only use the “workaround” of exporting the TIF, which, as I explained, isn’t an acceptable solution at all.
Please help me, thanks
edit: I’ve tried experimenting with the bug a bit more and if I use the LR plugin, but don’t use the Auto setting for denoise and sharpening, but change them just a slight bit, the issue is still there, but much less:
