Education | Cloud rendering options for Wonder in Topaz Gigapixel and Topaz Photo
Cloud rendering is necessary unless you want to wait 10 minutes plus to process Wonder on your computer. My workflow is to use Lightroom Classic for initial processing, Photoshop for additional work if necessary & then use Gigapixel or photo for the final work.
Cloud rendering is not available if I use Lightroom then transfer into Gigapixel. This means I really cant waste time using Wonder and will have to review whether just reverting back to Photo AI if additional features on Gigapixel & photo will take too much processing time without access to cloud. Very disappointed so far as I cant see much benefit if cloud rendering is not available from photos transferred from Lightroom Classic.
Hi Graham.
It’s unfortunate, Topaz Gigapixel doesn’t currently support Cloud Rendering for Wonder when used as a Plugin for both Lightroom Classic and Photoshop, hopefully in the future Topaz will add this feature.
Fortunately, Wonder Cloud Rendering is available within Topaz Photo when used as a Plugin for both Lightroom Classic and Photoshop.
Hope this helps
There is no option on my computer to use cloud rendering on Wonder in Topaz Photo. Are you referring to purchasing cloud credits for Topaz Photo? It is included in Topaz Gigapixel provided the image is not imported from Lightroom.
Why is cloud rendering disabled when importing from Adobe programs?
Apologies, Cloud Rendering is only available for Topaz Photo and Studio Subscribers as you mentioned reverting back to Topaz Photo AI, I assumed you had a Subscription.
I don’t work for Topaz but, hopefully they add it at some point in the future for Gigapixel
There is an option to hide the cloud rendering options in Topaz Photo, maybe it’s hidden on your app?
  • In Topaz Photo, cloud rendering will work as a plugin, and it’s free.
Thank you. Cloud rendering was set to “off”.
