I fully appreciate the Autopilot but sometimes the effects that are applied have more impact than I want them to. How can I fade effects? Simply “turning down the volume”?
Kind regards,
Adam, Denmark
Kind regards,
Adam, Denmark
You can control the strength of each enhancement in two ways:
Preferences (Autopilot Settings): You can adjust the default behavior of Autopilot so effects like Sharpening or Denoising are applied more subtly from the start.
Enhancement Controls: After an image is processed, you can manually fine-tune the strength of each applied enhancement (like adjusting the “Amount” slider under Sharpen, for example).
We have a couple of quick guides that walk through both options here:
Hi John,
Like many others - I am sure - I prefer learning by trying. So - thanks for advice; I found the sliders and I am very pleased with the outcome!
Best regards,
Adam
Med venlig hilsen
Adam Pade • Redaktør |
