Topaz Photo AI works well as an ON1 Plugin. Can Topaz Photo be used as a plugin?
Hi.
Yes currently it’s essentially the same application so yes, you can use it as a Plug in
Hope this helps
I found the .8bf file and copied it to the appropriate ON1 folder (Preferences>Plugins).
It works fine now.
I assume you are on a PC where the procedure for getting it to work might be different. Glad it does. There is always a bit of trial and error involved!
It is a PC.
