You know where it says ‘Show Export Command’? Make that box editable, so cliking on ‘OK’ actually saves the command line. Now you have to do all sorts of convoluted things, like setting environment variables (or keeping GUI open), and then use a command line prompt to paste the export command in. Instead, just make the ‘Show Export Command’ editable, so, upon OK, TVAI will use that for export. Will be a real QoL improvement!
