Subject: Quality differences between Proteus (2×) + Proteus Natural (2×) double‑inference workflow and the Auto mode of Second Enhancement Intermediate.
Overview
During extensive testing on SD sources upscaled to 4K using Topaz Video AI 1.7.0, I observed a consistent and reproducible difference in both quality and performance between:
Manual double inference:
Proteus (2×) → Proteus Natural (2×) -
Auto mode:
Second Enhancement Intermediate = Auto
The manual double‑inference workflow produces significantly higher visual quality, especially on faces, textures, and noise stability, while the Auto mode produces lower quality but nearly double the rendering speed.
Detailed Findings
1. Quality of Manual Double Inference (Proteus 2× + Proteus Natural 2×)
When using a cascading workflow:
SD → FHD → 4K
with
Proteus (2×) followed by Proteus Natural (2×)
the resulting image quality is consistently superior. Improvements include:
Better reconstruction of facial features
More natural skin texture
Reduced noise amplification
Fewer halos and edge artifacts
More stable frame‑to‑frame consistency
Higher fidelity in fine details (hair, eyes, fabric, shadows)
This workflow appears to benefit from the progressive resolution increase, where the first pass reconstructs details and the second pass refines them.
2. Performance of Manual Double Inference
On a high‑end system (RTX 5090M + Intel Core i9‑285HX), the rendering speed is:
- ~7.1 FPS in double inference mode
This is expected due to the heavier computational load of two full 2× enhancement passes.
3. Quality of Auto Mode (Second Enhancement Intermediate = Auto)
When enabling Auto mode, the pipeline behaves differently:
SD → “SD improved” → 4K
The intermediate step remains at a low resolution, which causes:
Loss of fine detail
Increased noise visibility
Artificial textures
Lower facial fidelity
More unstable micro‑details
A “plastic” or oversmoothed appearance in some scenes
Because the intermediate resolution is not sufficiently high, the second enhancement pass lacks the necessary detail to reconstruct a clean 4K image.
4. Performance of Auto Mode
Auto mode is significantly faster:
- ~16.5 FPS, more than double the speed of manual double inference
This is consistent with the reduced computational cost of processing a lower‑resolution intermediate frame.
Conclusion
The current Auto mode of Second Enhancement Intermediate prioritizes speed over quality.
For users seeking maximum visual fidelity—especially for SD sources, faces, and fine textures—the manual workflow:
produces substantially better results, albeit at a lower rendering speed.
Conversely, Auto mode is useful when speed is the priority, but it does not match the quality of the manual double‑inference pipeline.
Recommendation for Topaz Labs
It may be beneficial to:
Expose more control over the intermediate resolution used in Auto mode.
Allow users to choose between:
Quality‑optimized Auto (higher intermediate resolution)
Speed‑optimized Auto (current behavior)
Consider a hybrid mode where Auto selects the best model but still performs a true progressive upscale (SD → FHD → 4K).
This would give users the flexibility to balance quality and performance according to their needs.
As usual, feel free to ask me more explanations!
Best regards, Vincent.
