Does connecting monitor directly to gpu slow down topaz video ai export times?
Does connecting monitor directly to gpu slow down topaz video ai export times? Would it be faster if i plugged my monitor into my motherboard?
I have two GPUs, one for the monitor and the other for calculations. It doesn’t noticeably speed up calculations, but everything else on the system seems less prone to hangups.
i see the export time increase when I turn my monitor on
Using a separate GPU to drive the monitor should help with that.
Running a monitor or multiple monitors does pull some resources out of the VRAM which in turn could negatively effect a videos processing rate. Connecting a single monitor, depending on the size though should not have too much of an effect but if you are running a multiple monitor set up with HDR enabled and high refresh rates it could have a bigger impact.
